Can anyone tell me if there is a prequalified wps for welding dissimilar metals such as a 304 stainless to a A-36 using a FCAW process? The joint design is a lap joint (fillet, no edge prep.) in a 2F position material thickness is approx. .750" the electrode would probably be a 309, .045" dia. Time is of the essence and I would like to get around having to qualify the procedure if possible. I have seen some publications that reference this but they were designed for materials from 10 - 18 ga. these were qualified through the Welding Research Council and had documented supporting pqr's. This wps can either be ASME or AWS, either will work for this project. If anyone has this info and would like to share it, please, E-mail me at Wldr61@cs.com. Thanks for any help on this issue.
C. Miller
