Up Topic Welding Industry / Technical Discussions / HIGH FREQUENCY FOR TIG WELDING
- - By centroidindia Date 05-19-2002 12:19
Sir,
I have an Inverter Based TIG Welding Machine of 140 Amps. 100% Duty Cycle, 220V AC. I am planning to connect an External High Frequency Unit.Kindly Clarify on the following:
WHAT SHOULD BE THE VOLTAGE AT THE SECONDARY SIDE OF THE HF TRANSFORMER?
KINDLY SUGGEST A SIMPLE WAY TO MEASURE THIS HIGH VOLTAGE.
VENKAT
Parent - - By Lawrence (*****) Date 05-20-2002 13:55
Venkat,
We can prolly be of greater assistence if you can add the following information
Manufacture and Model of your Inverter machine
Material type and thickness you intend to join
The reason you feel High Frequency is required above and beyond the regular capabilities of your machine.
Most manufactures supply after market HF boosters but I've never heard of one being needed to assist an inverter in the area of arc starting (which is what I am assuming you require the HF for), even with leads approaching 100 feet (30 m) in length. This makes your question interesting...
Parent - By DGXL (***) Date 05-20-2002 14:42
Ditto.
