Up Topic Welding Industry / Technical Discussions / About ASME IX bend test!
- - By playboy1898 (*) Date 12-10-2009 07:17
According to the QW 466.1, if we have two different material in one coupon. One parent material elongation is 24%, the other elongation is 18%, How to choice the bend roller?
Parent - By 803056 (*****) Date 12-11-2009 04:26
Base the radius on the weak link, i.e., the material with the lowest elongation. Don't forget to consider the properties of the filler metal as well as the two base metals being welded.
Parent - By MBSims (****) Date 12-11-2009 05:09
As Al said, the bend radius must be based on the material with the 18% elongation.  Note B in QW-466.1 states "The dimensions of the test jig shall be such as to give the bend test specimen a calculated percent outer fiber elongation equal to at least that of the base material with the lower minimum elongation as specified in the base material specification."
percent outer fiber elongation = 100t/(A + t)
Since the note says "at least", a smaller bend radius would be permitted.
