Up Topic The Welders / Welding Equipment Classifieds / circuit board for trailblazer 301G
- - By brian martin (*) Date 12-12-2009 00:55
hey im wondering if any one out here know what kind of money im going to drop on a circuit board for  my welder???
Parent - - By weldersales (**) Date 12-12-2009 16:26
See if your board is a 212708. If so, we can probably repair it. Miller list is 429.87. weldersales
Parent - - By brian martin (*) Date 12-13-2009 02:53
hey thaqnks for the reply, thats not the one i need, the one i need is model number212867  its the circuit board with the heat control and the process knob, mine isn't burned up or anything  the only thing wrong with it is the heat control knob got knocked off  and don't know anybody around where i live that can fix it
Parent - By weldersales (**) Date 12-18-2009 21:18
I believe we can replace that. weldersales
- By leroyhall Date 03-07-2018 23:06
Does anyone have a schematic diagram for the Miller trailblazer 301D PCB 212708?  Parts available?  Could I talk to some one about how it works?  The main and exciter field have DC resistances of approximately 3 ohm and 30 ohms.  Is this OK?  How about the coil that feeds the bridge rectifier, what should it's resistance be?  My email is Leroy@leroyhall.com
