Greetings,
I dont have much experience in D1.1 Structural pipe and i am under the gun with time restraints!
We have a rush job with a couple 18" pipe T,K,Y Joints that are under the Prequalified 30 degree limits.
We have no procedures for open root, so we plan on welding a backing weld on the inside and backgouging from the outside. We will splice the pipe to gain access to the inside.
Do I need to qualify a WPS for this?
Do I need to Qualify welders on 6GR or will 6G work.
I believe the 6GR is for tight spots (T,K,Y) but do backing or open root a requirement?
Please clarify.
Thank you!!
David
