Up Topic Welding Industry / General Welding Discussion / SA 200 maintenance
- - By argoncowboy (**) Date 12-27-2009 20:53
I just got my 56 shorthood back from the rebuild shop. I've only run my 250 diesel so I am not sure of the oil change schedule on this newly rebuilt 200. Can anyone inform me of the oil change intervals on this machine. Thank you
Parent - - By TRC (***) Date 12-27-2009 22:30
My manual for my 69 says 50 hrs but i've talked to mechanic's that say 250.
Parent - - By Cumminsguy71 (*****) Date 12-27-2009 23:25
If you've just had the engine rebuilt I'd change it at 50 hours for your initial oil change. You'll have some wear on bearings and such where everything is mating together and you'll end up with a bit more heavy particles than normal. After the initial oil change I'm not for certain, maybe 250? I bet lincoln has the owners manual online where you could find out.
Parent - - By chris2698 (****) Date 12-28-2009 01:33
my manual says 50 hours
Parent - By argoncowboy (**) Date 12-28-2009 02:23
Thanks Guys
Parent - - By raftergwelding (*****) Date 12-29-2009 06:32
i do mine once a month
Parent - - By shorthood2006 (****) Date 12-29-2009 12:59
if you havent installed an hour meter, i would....just so you will know how many hours are on the overhaul if you decide to sell the machine....the first question asked is "how many hours is on the overhaul" i change mine every 100 hours.
Parent - By argoncowboy (**) Date 12-29-2009 15:39
I installed an hour meter for that very reason. Allthough I think I am very impressed with the way it welds so I can't see me selling it.
Parent - By raftergwelding (*****) Date 12-29-2009 16:31
the machine im running now came with 1 i junked it and put an oil pressure gauge in its place
