Up Topic Welding Industry / Technical Discussions / AWS D1.1 Welder Qualification
- - By LTRN Date 06-03-2002 17:15
If a welder is qualified with SMAW, SA36 plate (no backing) in the 3G and 4G positions is that welder qualified for all fillet and groove welds including pipe regarding the AWS D1.1 code ?
Parent - - By kpauley (*) Date 06-03-2002 19:14
See Table 4.9 in AWS D1.1:2002. Page 140.
Parent - By LTRN Date 06-04-2002 12:27
Kpauley,
If I may ask, what is your interpretation of table 4.9 in connection to my question?
Parent - By Wildturkey (**) Date 06-04-2002 12:56
only on pipe greater than 24" diameter for groove welds (note 3).....dont forget about the thickness limitations
Parent - - By R. Johnson (**) Date 06-04-2002 13:10
I believe you need to look at Table 4.8. And the way I interpret the table, the welder would be qualified for all fillet welds in any position. Grooves in pipe would be limited to pipe over 24 inches in diameter with backing, backgouging or both. For partial penetration groove welds in pipe and box tubing the welder would not be qualified for welds with a groove angle less than 30 degrees. And of course the dihedral angle restrictions for fillet welds. Hope this helps.
Parent - By LTRN Date 06-04-2002 14:07
R,Johnson & WildTurkey
In response to your interpretations addressing my welder qualification question : I do agree 100% with the replys.
Thought I would pass it by the forum, sometimes the obvious is overlooked or misunderstood.
Thank You for your input.
Parent - By Wildturkey (**) Date 06-05-2002 12:28
you are correct.....i just didnt take the time to write it all down
