By brrrrp
Date 02-03-2010 12:06
David,
Sorry for the late post, but new to the forum. Paragraph 3.3.7.6 of AWS D1.5, Bridge Welding Code provides you with your answer. The backing bar only has to be welded full length if there is any attachment weld external to the joint on a given side. They just want to make certain that for a cyclically loaded joint, there are no intermittent welds present. So, a continuous weld on one side, and no external welds on the other side of the backing bar is acceptable. As an alternative, Paragraph 3.3.7.5 allows tack welding within the joint on the side where there are no external welds holding the backing in contact with the base metal.
Regards,
brrrrp
