ASME IX
QW-452.1
Thickness of weld metal in coupon - Thickness of weld metal qualified
All - 2t (2 times test coupon thickness)
1/2" and over with a minimum of 3 layers - Maximum to be welded
QW-452.3
Outside Diameter of Test Coupon - Min Qualified - Max Qualified
Less than 1" - size welded - Unlimited
1" to 2-7/8" - 1" min - Unlimited
Over 2-7/8" - 2-7/8" min - Unlimited
With that said, if you had run a GTAW root on the monster coupon (2-3/4" x 5/8"), you would have been qualified to weld 1", sch 10, ss pipe if you had run the GTAW process all the way out. But without knowing what process you qualified on, and all the particulars of what you were welding on, it's hard to tell. And then on top of that, every company has the right to test you in any process they want. But if you are going to weld smaller than 1" pipe, then yes, another test would be required.
