I read you loud and clear Superflux!!! :) :) :)
You said it Al! ;) Scrappy did get a whole lot of heat in that thread mainly because most of the folks who were critizing him didn't fully understand what he was actually doing inside a huge Power boiler which more than likely 90% or more of the responders never even set foot into one of those, and were clueless as to what one would actually encounter in one of those boiler, much lees have an idea of how they are actually designed in such a way that there are indeed inherent redundancies designed and built into these huge power boilers in the first place!!! ;)
I personally worked on just about every type of power boiler design used in both fossil fuels as well as waste to energy (Co-generation) Power plants. So if you were to transport me (Beam me up Scotty!!! :) :) :) ) spontaneously into one of them without any knowledge of where I would end up, or without the aid of engineering drawings, or any type of mapping aid of the plant. I know for a fact that I could find myself around one within 2 minutes maximum and find my way out of one of any size or type within 5 to ten minutes on average... Why do I bother stating this??? Because there are only a handful of folks in here besides myself who can claim the same with some degree of confidence!!! :) :) :)
I say this because I was personally upset at the amount of attacks that were not only lodged at Scrappy (He could have explained himself a whole lot better which didn't help in trying to understand what he was actually attempting to describe in the repair procedure with the so-called "Magic rods"! :( ), but at Boilermakers in general yet for the most part, I refrained from making any comments of my own until very late into the thread...
The type of repairs that are made in these power boilers are only a temporary "band-aid" which is sometimes used as a result of not having enough within the budget for for that particular shut-down to include a permanent type of repair via removal and replacement of such tubes. So the actual permanent repair are then included into the next budget for the following year's annual plant maintenance shut-down...
Usually this happens because the condition/situation didn't exist, or was overlooked in the previous inspection cycle, and was only discovered after the budget was already allocated, and well into the maintenance shut-down period which made it highly unlikely that any more money from the already allocated budget would be used to perform a permanent repair until the next maintenance cycle... Although the EOR's and the SCWI's don't like to admit it, they do these types of temporary, "Bubble-gum like, Band aid" repairs quite often unfortunately for Scrappy!!! :( :( :(
The point I'm making is that Scrappy did not deserve such a "feeding frenzy" that he experienced in that thread, and I'm really glad that he's preparing himself to take a different track in his career by his desire to become a welding inspector eventually!!! :) :) :)
What really has me scratching my head in this thread is how we got to even include slag in the discussion of the topic in this particular thread when the OP mentioned quite clearly at least to myself that the welding process was a pulsed welding process which could also mean pulsed GTAW since "Boss Man wasn't specific in describing the actual welding process being used... Nonetheless, both Pulsed GTAW and GMAW-P use bare filler wire that have no flux so, I'm just wondering how slag got into the discussion...
Perhaps Joel could explain better to us why by clarifying what he was describing to us in his previous post, because I personally have noticed over time that Joel is a very sharp individual despite his own personal lack of - shall I say "seasoning" that one only gets through tried and true experience, and yet his sponge like desire of wanting to possess more and more knowledge as well as his refreshing honesty in admitting that he doesn't know it all along with not being afraid at all to dive into the work and personally getting his hands dirty which is a very unique quality of a welding engineer, shows me at least that he is most definitely on track into becoming one of the best of the best anywhere IMHO. ;)
Well now that I have stroked your ego a bit Joel, could you please clarify what you were trying to describe to us in your previous post??? ;) :) :)
