Up Topic Welders and Inspectors / Welding Equipment Classifieds / 1967 REDFACE
- - By raftergwelding (*****) Date 01-30-2010 21:44 Edited 02-12-2010 07:57
SOLD IT TODAY
Attachment: redface1.JPG (0B)
Attachment: redface2.JPG (0B)
Attachment: redface3.JPG (0B)
Attachment: redface4.JPG (0B)
Attachment: redface5.JPG (0B)
Parent - - By southtexasman Date 01-31-2010 05:55
hey bud you got any pics?and what part of tx r you in?...very interested...thnx...
Parent - By ibeweldingsum (***) Date 01-31-2010 06:55
south of san antone about 35 mi.
Parent - By raftergwelding (*****) Date 01-31-2010 07:33
ill have some pics up in a few days i live in jourdanton next to pleasanton 35 miles south of san antone
Parent - By raftergwelding (*****) Date 02-02-2010 01:40
pics have been added and my number is in my signiture
Parent - By raftergwelding (*****) Date 02-10-2010 11:42
i guess your not intrested anymore huh
Parent - - By JLWelding (***) Date 02-11-2010 00:34
I hear you Shad, I am on my 4th vp44. that worked out to 17k miles to the pump. That some expensive driving at 1200.00 each
Parent - - By jason ritnour (*) Date 02-11-2010 01:41
the gas companies took all the sulfar out of the fuel and its burning everybodies pumps out becuase theres nothing in the fuel to lubricate them . I add 2 stroke oil to my fuel when i fill up and had good luck with my truck .
Parent - - By 52lincoln (***) Date 02-11-2010 02:28
y the two stroke oil.i was told trans fluid works the best.just wondering
Parent - - By raftergwelding (*****) Date 02-11-2010 05:00
i use a product called diesel kleen works pretty good. wished i knew why that turbo went out helol a month ago the lift pumpo went out and 2 weeks ago i rebuilt the front end
Parent - - By JLWelding (***) Date 02-11-2010 18:40
If your running K-N air filter your cummins motor has so much air flow it will pull holes thru filter and then you sucking straight dirt. If you over oil filter then it will cake up with dirt and eat it up. K-N not good for cummins. If you go to mopar1973man.com and look up BHAF air filter that is the way to go it will lower your egt also.
Parent - By raftergwelding (*****) Date 02-12-2010 07:59
Im runnin a k n it came with it and it has a sock on it i looked when i got the turbo off not dirt build up i dont know why it went out i found a turbo in boerne w 30,000 miles on it for 150.0 oicked it up yesterday rain is spose to let up so when i get back from takin mom to the hospital ill be back on the road tomorrow afternoon and headed to rock port for a metal building job
Parent - By JeremyW83 (***) Date 02-11-2010 15:24
Do not put old ATF in your fuel tank itll destroy the newer diesels that we all drive.
Parent - - By raftergwelding (*****) Date 02-11-2010 05:01
Joe if you think you can make that bed of mine you looked at work you can have it for 300 i need the money
Parent - By JLWelding (***) Date 02-11-2010 18:33
Shad I am so broke right now I cant pay attention. It is a real good bed to start out with though.
Parent - - By JeremyW83 (***) Date 02-11-2010 15:21
JL where have you been getting you IP.  I hope that it came with a warranty.  I use MidWestFuelInjection.com  These guys are awesome and will take the time to answer all of your questions.
Parent - - By JLWelding (***) Date 02-11-2010 18:31
Yea its under warranty but I have to pull it off and send in and it might take 5-10 days to get it back. And it not throwing a code yet so I was told they may just send it back and if it keeps doing it, then what? thats where I am at for now. Good to hear good info on rebuilt pumps. Mine is from industrial injection. I dont under stand it I been running 2 stroke oil for 2 years now, but I guess it is in elec. As far as the new trucks 2007 and lower you can run 2 stroke it will screw up newer trucks.
Back to pump, it died a bout ten times in 20 mile, it wont die completely keeps running a little then back to normal. I have replaced everything under the hood I mean everything. I should have p pumped it when It first happen. Cost about 3500.00 to p pump.
Parent - - By JeremyW83 (***) Date 02-11-2010 19:50
What year truck do you have?  I think it is 2000 and up you can turn the ignition on and off three times and it will sometimes show any codes for the pcm and ecm.  What is your fuel pressure?  If it is more than 20 over time it will wear out the internal diaphram and cause the pump to start going out.  I didnt know that you could p pump a 24V that cheap.  I know you have to change out the ecm and I think the injectors as well.  Plus I think ou need something like 45 psi of fuel pressure to make it run correctly.
Parent - By JLWelding (***) Date 02-11-2010 20:41
01 Dully-Skirted Flat Bed Welding Trk-Weight 9900-SA 200 Lincoln-Edge Ez-Boost Elbow-Pricol Optix-Fuel-Boost-Egt Gauges-Bhaf- 5 Inch Diamond Eye Exhaust -Airdog 100-Two Stroke Oil-RV 275 Injectors-BD Intake-Amsoil-Southbend Clutch -Grid Heater MIA-234k -jlweldingtx.com
It has 15 lbs at idle and 13.50 at wot. as far as p pump that is the price I got from shop in my area. So I guess it just a ball park. but at 4 pumps man I am willing to try anything at this point. I got a lot invested in it so it is hard to bail on it now.
I am thinking on a new wire harness.I sent Edge Ez back and they said I had croision on board and they sent new edge to replace it with. I ran it for about a week with out a controler on it and it still die on me twice. Cleaned all conections and grounds.
- By jason ritnour (*) Date 02-12-2010 03:43
auto trans fluid is good you just have to be carefull what kind you get some have friction enhancers for the clutchs in the transmision
