Up Topic Welding Industry / General Welding Discussion / Trouble with 300D
- - By okie (*) Date 01-31-2010 19:45
Will weld about 5" and slowly run out of arc put on high idle will not keep full RPM even with grinders runs the same any info would be helpfull. Thanks,
Parent - - By Johnyutah (**) Date 01-31-2010 21:07
Fuel problem most likely a filter at least that was my problem.
Parent - By pipehead (***) Date 01-31-2010 22:52
Does it eventually die? Mine did something similiar but would eventually die ended up being the alternator
Parent - - By okie (*) Date 01-31-2010 23:33
It never died but struggled to keep running.
Parent - - By okie (*) Date 01-31-2010 23:38
I replaced the battery charging just fine
Parent - - By pipehead (***) Date 02-01-2010 00:07
Mine charged just enough to keep the battery okay but for some reason it would only weld about 5inches then screw up
Parent - - By Johnyutah (**) Date 02-01-2010 03:44
Which motor are we talking about.
Parent - - By okie (*) Date 02-01-2010 12:19
Perkins
Parent - By Regmanager (**) Date 02-01-2010 12:50
Take the air filter out and see what happens.
Parent - - By DaveBoyer (*****) Date 02-02-2010 02:05
If the air filter is clogged it will make dark smoke under load. If the fuel filter is cloged it will just die out when load increases.
Parent - By litchko (*) Date 02-02-2010 02:38
If it has a glass bowl, there is a fine screen above it that tends to plug up(had this problem a couple times).Turn the pedcock ,off undue  the thumb screw on the bottom of the glass bowl(watch you don't break it,sometimes there stuck on pretty good)if you look up underneath you'll see the fine screen just be careful when you remove it .Hope this helps you.Regards,Bob
- - By okie (*) Date 02-02-2010 08:47
Thanks for all the info fuel filter was full of rust and shaveing changed everything out good as new.
Parent - - By Johnyutah (**) Date 02-03-2010 00:55
Looks like I win that one.
Parent - - By shorthood2006 (****) Date 02-03-2010 01:10
congrads!
Parent - - By Johnyutah (**) Date 02-03-2010 01:33
It's the little things in life.
Parent - By 63 Max (***) Date 02-03-2010 20:45
It's the little things in life that I think most of us do on a routine basis, fuel filter, oil, oil filter, air filter. I think they call it preventive maintance. lol
