Up Topic American Welding Society Services / Technical Standards & Publications / 3G/4G Welder for Outfitting Tubular/Box Tube Items
- - By Nalla (***) Date 02-04-2010 04:10
Dear Friends
Applicable Code AWS D1.1 -Table 4.10
Isn't it a violation to code using 3G/4G qualified welder to weld 8" Bumper Frame(Pipe) & Handrails( Non-Load Bearing Items)?
Thanks
Parent - - By 803056 (*****) Date 02-05-2010 13:57
Only if the bumper frame is covered by a code.
The bumper in a parking garage may not be considered to be a "structure" in that it doesn't support a load as is the case with a steel framed building. If that is the case, the designer or EOR may consider the bumper outside the scope of D1.1.
I would direct the question to the owner or the owner's engineer.
Parent - By Nalla (***) Date 02-08-2010 04:05
Dear Sir
After much discussion,client Engineer approved to use 3G/3G Welders
Thnaks
