Dont have any manuals or referances here at home, but...
in general I believe the weld joints are pre-qualified meaning the bevel degree and root opening. Now keep in mind that there are additional requirements of the seismic code that may apply, and if so they require recertification of the welder, but not the WPS.
Those are that there shall be no starts and stops in the center/ web area of the joint. The welder must pass through the rat hole during welding. ALso each LAYER shall be completly welded before continuing on, IE the welder can't weld all the passes on one side of the joint until the bevel is filled and then weld the other side, they have to finish each weld/pass/layer before contining.
I'll look into this more tomorrow at work.
Chris
