[quote]"If anyone uses these equations"[/quote]Krautkramer has those laminated charts too.
If anyone does any angle beam inspection at all, they will use these formulas over and over every time they inspect. You need these equations, unless you depend on the machine to do all of the calculating for you(which is kinda dangerous). Basically it is nothing more than a little trig that you apply to any triangle.
To make sure that you cover at least the three legs during angle beam inspection; use these 2 formulas to figure how far back from the welded joint that you need to cover enough of the material with your scanning pattern.
Hope this makes sense....
