By 803056
Date 02-12-2010 04:43
Edited 02-12-2010 04:45
Hello John;
I agree with your comment about over analyzing the questions. Some people add to the question. I had one fellow respond that the largest single pass fillet weld using SMAW made in the vertical position was 1/4 inch.
I asked him how he came up with that answer instead of the expected answer of 1/2 inch.
His response was that if he was welding on weathering steel he was limited to 1/4 inch by clause 3.7.3.2.
I said there is nothing in the question that indicated weathering steel was being welded.
His response was, “but if I did weld weathering steel I would be limited to 1/4 inch.
I said that was only if the weathering characteristics were to be retained and an electrode with matching weathering characteristics was not used.
"But if I didn't select the proper electrode I would be limited to 5/16 inch fillet welds in the vertical position." He said.
"Those conditions are not part of the question. You are adding conditions that have nothing to do with the question asked." I told him.
He insisted he was right, so I told him good luck. See you next year.
Read the question as it is written. Do not add conditions or add "what if" situations to the questions when answering them.
Ahhh,
The infamous Part B!
The conquerer of those who have come to master the BEAST (CWI exam).
I do believe, all the folks I know personally over the years who have failed the exam have fallen prey to Part B.
My secret to success for Part B would be to clear your mind of all that is conventional and accept Part B for what it is. PART B! It is an entity all of it's own. I think too much real world experience clouds the Test Takers' objectivity into wanting it to be stricter than it is. AND, it IS strict in it's own bizarre way, if that makes any sense. There is also some nomenclature snuck in there that separates those who truly know Welding Teminology and applying those definitions into this mock scenario. It is in my opinion an excellent addition to the Exam. When I first took the CWI in the mid '80s, the 3 part multiple guess format got pretty boring by the 3rd session. Part B is a nice break. Especially if it is the 2nd or 3rd installment.
Now, and I quote "well maybe Section VIII is a bad example" (ASME = always, sometimes, maybe, except) that is funny stuff, but I found API 1104 with it's "give the owner anything it wants" clauses to be a really tough nut to crack on exam day. The only reason I've used 1104 (3 times) is because I paid for my test and that is the Cheapest code to purchase!
The good news is, that just going in for Part B should give you the opportunity to focus on this one segment. Not all stressed out with from the other 2. They are done and over with!
"Free your mind young Skywalker, trust your feelings".
As I always say, "If it was easy, my Grandmother could've crocheted two of 'em while watching a re-run of Golden Girls."
Hope this helps, and best of luck to ya.
