“it looks like you burned your edges”
Is that good or bad?
I’m more in the hit and miss situation. I’m not near as consistent as I’d like to be.
Question for you, does your root have a little too much penetration? Seems as I’ve read 1/32nd to 1/16th, bottom line I guess it would depend on the code. Just can’t get a straight answer from anyone, any advice you’re willing to share?
