I need to move an engine mount on an 88 honda civic forward about an inch and a half. the mount was only tack welded to the unibody in six places from the factory, and was pretty easy to remove. Both the engine mount and the unibody are pretty dam thin, and i am not sure exactly what their metal compostition is. Can I perform the weld with smaw? if so, what electrode should be used? should I just tack weld it into place like the factory did, or should i run a bead all the way around it to be safe? should it just be a single bead, or like a three layer fillet? I appreciate any advice you can give me...
Oh yeah, don't worry, I do have a scrap unibody and mount to practice on before touching the car.
