Need more info regarding the thickness of the material, the joint configuration, the method of transfer you're going to use, what position are you going to deposit the weld in, etc.
How about giving us an idea what you were going to use as welding parameters including travel speed, % of Argon & Helium shielding gas, etc. ;) What type of set up are you working to? ;) ;) ;)
