Anybody out there with experience in SAW - welding of kiln (3 metres in diametre & 40 tonne weight) circumferential welds (2" wall thickness). I need some ideas regarding joint preparation (with gap or not?), restraining method, welding technique, how to avoid excentricity, rotating method, etc.
zambrota, your company has bought a cement kiln that cost a lot of money. Didn't the kiln manufacturer supply the assemblying and erecting instructions? If not, you should demand them, it's their obbligation to furnish them. Quite often, however, equipment manufacturers don't supply erection instructions, or the ones they supply are quite vague, so the purchaser is compulsed to buy the services of their field engineer, which are not cheap, by the way. Dear zambrota, in my opinion, the instructions you're asking for are complex and too long to explain, and fall beyond the purpose of this Forum. My advice is that your company calls in the manufacturer's field engineer or appoints a welding consultant. Do you Gentlemen who are frequentors of this Forum think the same way? Giovanni S. Crisi Sao Paulo - Brazil
Giovanni, I sure ain't no kiln guy. But in my assessment the fit up, welding, and rolling per se are not the problem (assuming you can move this monster with relative ease). This is not unlike some big pressure vessels we've done. Dogging for ovality, bed rollers for welding, and a double bevel to reduce welding time and weld material consumption seem pretty basic here. You can run SAW tracking for the ID and syncronize your "can" roll with your travel speed. Use a closed butt and backgouge. Then run a standard manipulator boom with SAW on the OD. The problem to me is how long is this thing and keeping it all in square through its length. I am not disagreeing with you however. Not at all. It seems that some professional help is certainly called for here.
I would seriously call these folks especially if you already have their equipment to weld this job you're talking about... If you don't have Lincoln equipment, then why don't you get in touch with the SAW Equipment Mgfr. and ask them for some technical assistance??? And if they will not provide you with help, well then I believe it's quite obvious what to do - don't you??? ;) ;) ;) BTW, do you have any of the Lincoln educational books??? The Procedure Handbook of Arc Welding should be a valuable resource for this application as well as some of the other books they offer in the James F. Lincoln Foundation webpage:
Well there you have it Zambrota... I believe out of all these contacts ,at the very least you should find one or two who will assist you in answering most, if not all of your questions regarding the welding and fabrication of Rotary Kilns and Dryers based on the amount of experience they have so long as you ask very, very nicely and demand absolutely nothing - CAPECHE??? ;) ;) ;)
