Up Topic Welding Industry / Technical Discussions / titanium?
- - By joe davis (*) Date 02-18-2010 14:00
does anyone have advise on welding one inch titanium tubes .050 wall in accordance with d17.1 without a gas chamber I'm having trouble with color.
Parent - By ssbn727 (*****) Date 02-18-2010 14:31
Hi Joe!
"WELDCOME TO THE WORLD'S GREATEST WELDING FORUM!!! :) :) :)"
Can you be more specific? What is your shielding gas flow rate??? What size cup are you using and are you using a trailing shield of some type, and are you purging??? Also, what are your pre-welding cleaning/prep procedures??? In other words, you need to come forth with a heck of a lot more information and specific details that what you're currently describing in order for any of us to be helpful to you! ;)
Parent - By Lawrence (*****) Date 02-18-2010 14:33
Minimize heat
Extra large cup,  Many Ti welders construct their own cups... Kinda like a lightsaber  :)
trailing shield usually helps but it would have to be a custom job for 1" pipe.
The work is very doable without a purge box...  Just gonig to take some trials or an experienced helper with the tools.
And as Henry suggested... say more
Parent - By G.S.Crisi (****) Date 02-18-2010 14:41
Get in touch with the kings of titanium: The Titanium Company of America
www.timet.com
They'll be pleased to help you.
Parent - By MMyers (**) Date 02-18-2010 17:04
Are you doing this manual or using automatic orbital equipment?
- - By joe davis (*) Date 02-18-2010 17:24
Ok as per the wps Im running 20 cfh on the root and 10 on the top with a number 10 cup (the wps says a number 7 but that definatly isnt working) this is done in the 6g position and im running 35 amps DCEN on a synchrowave. If i use trail gas will that go against the wps.....
Parent - By Lawrence (*****) Date 02-18-2010 17:52 Edited 02-18-2010 17:54
Joe.
If you have a WPS than somebody at one point must have qualified that procedure...  If possible find them and get there gas shield data.   If it's an option is sure is the easiest one.
Edit:
10 CFH on a 5/16 id. cup is starving...   A gas lens with something around 20 cfh for that cup is reasonable.
Parent - By ssbn727 (*****) Date 02-18-2010 19:56
Hi Joe,
First and foremost especially with Titanium, "Cleanliness is Godliness!!!" So make sure you remove even the slightest oxide layer just prior to actual welding by using a dedicated Stainless steel wire brush just for Titanium... And this is to be done regardless of whether or not prior cleaning was performed beforehand because it doesn't take long for a thin film of Ti oxide to form over the weld surface - CAPECHE??? This MUST be done in order to ensure that there will be no Ti Oxide contamination within the weld area...
Then you need to make sure that when welding Titanium, you have a higher than normal purity percentage in both the shielding as well as the backing gas, and the trailing shield gas also... Typical specifications suggest that shielding gas be at least 99.995-percent pure with no more than 20 parts-per-million (ppm) of oxygen and a dew point greater than -50- to -76-degrees Fahrenheit. Other applications require a 99.999-percent pure flow of argon.
Outfitting your welding torch with a trailing shield is critical—otherwise the risk of oxygen contamination rises, and with it the potential for cracking. Some people fabricate their own trailing shield but there are also fixtures available for purchase. Trailing shields conform to the shape of the tube and follow the TIG welding torch around the pipe. The shields provide an extra protection of argon over the weld after the torch and its argon flow have passed. Setting the torch and trailing shield gas flow at 20-25 cubic-feet/hour (cfh) provides the best coverage. Now if one cannot use a trailing shield, then a really large bore gas nozzle cup is definitely recommended along with the use of a gas lens collet body that has a large enough diameter for the oversized gas cup one is going to use for Ti.
Back purging is also required when welding titanium tubing. This process eliminates the oxygen contained within the pipe by using any variety of a back purge dam: water soluble purges, non-rubber gaskets, specialty tape or inflatable bladders. Argon flows into the dammed area to replace the oxygen contained within the tubing. Allow the argon to flow long enough to replace the oxygen ten times over to ensure the purest welding environment. Always use a clean, nonporous plastic hose to transport the shielding gas to the torch, trailing shield and back purge. Rubber absorbs oxygen that could contaminate the weld.
Does the WPS have a post flow amount written in it???? Because if your post flow is less than 20 seconds, then this could be the cause of getting so much color in the weld... What you do not want to do is to remove the gas shielding prematurely - before the temperature of the weld cools down below the 800-degree Fahrenheit threshold. This is the point at which oxygen can no longer react with the titanium. Some codes may require that post-flow remain until the temperature drops below 500-degrees Fahrenheit, so always follow procedure, and if the procedure isn't sufficient, then revise it, so it does give the desired results-PERIOD!!!
Titanium offers the benefit of showing its true colors once the weld is finished. The final color of the weld joint indicates how well the shielding gas protected the weld from contaminants and how thick the oxide layer is. ;)
- - By joe davis (*) Date 02-18-2010 19:49
Ok I work on a military instalation we repair aircraft parts In accordance with AWS D17.1 However the WPS comes out of NAVAIR 01-1A-34  with that being said about the wps Im not sure how reliable it is or how it was tested but thats how the suits want us to test. One example of my mistrust is in WPS 4 the electode used on 6061 t6 alluminum is  EWTH2 BUT this causes ac spikes so i went with pure tung. and passed the Radiograph. so what im tryin to say is ill give trail gas a try and if my witnessing official says anything ill try to explain it to him .....we'll see what happens thanks
Parent - By ssbn727 (*****) Date 02-18-2010 20:07
It sure does read as if those folks are clueless when it comes to Titanium and Aluminum also for cryin out loud! ;) I'm glad you understand, and now it's up to them to open their own minds so that they can do the same... Hang in there Joe!!! :) :) :)
Parent - By Lawrence (*****) Date 02-18-2010 20:42 Edited 02-18-2010 20:46
Ok Joe
If your on an airbase.. It sounds like a NARF or at least an "I" level airbase if your doing that kind of work..   You should have tech reps from GE, Pratt, Allison, Boeing etc.. All the engine and structure makers.  These tech reps should have access to the standard practice manuals for Aerospace welding, prolly located in your tech library...
These should be very informative... And you and your supervisors should have access to them...
Details about surface prep, purge rates, backup fixturing etc. can be found in the standard practice manuals..
1595 and D17 are minimalist for a reason...  The reason is the wealth and diversity of standard practices founded by each of these major aerospace players...
As Professor Crisi noted the Ti institutes and EWI/TWI  have great data... much of that data was gathered collaberatively with the aerospace folks who publish the standard practices I've mentioned...
Hunt down the Tech Reps...  They are paid to help you do your job...  You are the reason they exist and mostly they are quite helpful.  These tech reps, through their tier one employers, shoud also have membership in EWI, TWI and the Ti institute and be able to to the legwork of finding the tools you need...  The research has been done for about 20 years... Ti is nothing new to these folks... Use em
Let us know what you find out.
- - By joe davis (*) Date 02-19-2010 14:37
we work on an airfield within a regular millitary base there is no engineers or tech people or even a library i know it seems hard to beleive but i am the most educated welder here noone i know has ever certified ti in the past if a part came in the guy i replaced just welded it and went on about his business (not smart). My supervisor is actually an old aircraft mechanic with some basic welding experiance nothing impressive so as far as my fountain of knowledge goes you guys are pretty much it.
Parent - - By 803056 (*****) Date 02-19-2010 23:26 Edited 02-19-2010 23:46
Hello Joe;
You have already received some good advice. All I can do is add my confirmation on a couple of points.
Shielding Gas: Argon purchased to AWS A5.32 is "pure" enough for welding titanium. Use the largest gas nozzle you can and if possible, use a gas lens to permit higher flow rates than would be possible without the gas lens. A trailing cup can be easily fabricated using thin gage stainless steel, a diffuser, and a "cape" made from a piece of "fire blanket.” The idea is to contain the argon gas to displace all oxygen and nitrogen, as well as hydrogen from the weld puddle (gas nozzle's function) and the weld as it cools to a temperature sufficiently low that it no longer reacts with atmospheric gases (the function of the trailing cup). You can also build a "bubble" or a chamber out of plastic film stretched over a wire frame constructed from welding rod. The larger volume of the chamber will require extensive purge and it will require a good volume of argon to lower the oxygen/nitrogen content to less than 0.5%.
Purge: You most definitely need to purge the ID of the tube. Block the ends with stainless steel wool that has been rinsed in 90% isopropyl alcohol and air-dried. You need to allow the air in the tube to be completely displaced by the argon. The (flow x time) should be sufficient to displace the system volume about 7 times to reduce the oxygen content to less than 0.5% (maximum). Air is less dense than argon, so there needs to be venting at the high points in the system to allow the air and excess purge gas (argon) to vent. I would use too high a flow rate with the thin wall tubing. Initial purge flow can be about 10 cfh and then it can be reduced to about 5 cfh if the vents are small. You do not want a positive pressure inside the system that will "blow-out" the molten weld puddle leaving a gaping hole where the weld puddle once was.
Cleaning: Wire brush all the joints with a stiff bristle brush that has austenitic stainless steel bristles after the piece and the wire brush have been cleaned in isopropyl alcohol to remove all traces of oils (including fingerprints). Do not handle the piece with your bare hands or using gloves that are not perfectly clean. Wipe down any fixturing or tools with the alcohol before using them.
Sweat or the use of chlorinated solvents can contaminate the titanium and it will cause it to crack if the part is reheated (as in the case of stress relief or annealing).
Rods, filler metal: Wipe down all filler metals with the alcohol before using them. It would be a good idea to clean them using stainless steel wool that has also been cleaned in alcohol and air-dried before using it.
Henry said it all when he addressed cleaning and the need to keep everything clean.
If you do everything correctly, the weld, exterior and root side, will be as silver as a new quarter. The discoloration will occur if there is contamination. It will go from silver to a light straw (pale yellow), to gold, to purple, blue, black, and finally gray ash. You need to strive for silver. Any more than a hint of yellow is a kiss of death unless you are doing a sculpture and you are looking for pretty colors for an entirely different reason.
Nearly anything will contaminate titanium. Sweat, fingerprints, oils, chlorinated solvents, dirty rags or welding gloves, dust in the air, etc. Some of the shops I have worked with have people tasked with vacuuming and cleaning all day long just to reduce the possibility of contamination. Adhesive tape will give off fumes when it is heated which will be absorbed by the weld puddle and it will cause contamination.
Grinding disks and other tooling must not be used on anything other than the titanium. Carbide rotary files are usually preferred over grinding disks.
This sample shows the affects of varying levels of atmospheric contamination. Wire brushing the weld will remove the colors derived from oxidation, but the damage is done and it is permanent. Once contaminated, the weld and adjacent base metal has to be removed before a structually sound weld can be made.
Parent - - By joe davis (*) Date 02-20-2010 00:42
great info al i really appreciate it. One more question in the picture you posted is any part of that acceptable because i can make it look like the far right but i do get thin blue lines just outside my cup.
Parent - By ssbn727 (*****) Date 02-20-2010 02:14 Edited 02-20-2010 13:12
Hello again Joe!
Here are some links that will be helpful for you to use as pictorial guides in determining the difference between a "good-sound" Ti weld, and a "bad-contaminated" Ti weld which you're trying to avoid in the first place...
This first one is from Miller Electric and it's a very good guide in itself to use in the fabrication and welding of Titanium... Take a look at the fillet weld deposited on the "Tee" joint shown in the 17th and 18th picture down from the top of the guide as you scroll down, then look at the picture below that and you shall see the importance of back-shielding as well.. Scroll down a little further and you'll find a picture where the different colors indicate the differences in weld quality... Although color alone doesn't always indicate in itself a difference between a "Good-sound" Ti weld and a "Bad-contaminated" Ti weld, it is a very strong and one of the strongest indicators in distinguishing weld quality:
http://www.millerwelds.com/resources/articles/TIG-gtaw-titanium-welding
This one is the design and fabrication manual from TIMET who just happen to be the world leader in Titanium production and expertise... Some of the welding information you're looking for can be found in pages 29 to 38 in the .pdf document in this link:
http://www.timet.com/pdfs/ti-handbook.pdf
This one from Kobelco has one of the most thorough Ti color carts and graphical representations covering the many different aspects of the many colors Titanium can have on it's surface due to not only welding, but also a variety of different surface treatments including anodizing, etc. In other words, it covers joining, heat treatment and surface treatment as well...
http://www.kobelco.co.jp/english/titan/files/details.pdf
This link is Ed Craig's web site, and it takes you right to his link on welding Titanium...
http://www.weldreality.com/Titanium%20Data.htm
Here is a very good visual page to show you what is acceptable color wise and also gives a tip on how to convert a basting cabinet into a welding chamber for Ti! ;-)
Not as technical as the first two links but nonetheless, it's a good link that shows the differences in color, or the lack of color in successful Ti welds! ;-)
http://www.weldingtipsandtricks.com/welding-titanium.html
This is a .pdf on the micro-structure of Titanium welds which in fact gets into the depths of what is going on within a "good-sound" Titanium weld and a "bad-contaminated" Titanium weld:
http://www.struers.com/resources/elements/12/38860/e-Structure%203_EN.pdf
This should give you enough of a visual reference to determine if your welds are "good-sound" Ti welds, or if they are still considered "bad-contaminated" Ti welds. ;)
I hope these links serve you well in learning more about successfully welding Titanium! ;)
Parent - By 803056 (*****) Date 02-20-2010 12:16
On my computer I am forced to use the slide bar at the bottom of the screen to see the full length of the welded sample. The far right end, where the weld is silver, is acceptable for most welding standards dealing with titanium. This sample was welded using a "homemade" trailing cup.The surfaces adjacent to the weld would not be discolored if this was welded in a chamber.
Best regard - Al
