Hi GRoberts!
"The length of your weld is 192 * Pi cm. Multiply that by the weld width. Multiply that by .02. That is the maximum porosity area permitted."
Not for nothing but, does
"192 cm * Pi cm." mean that the total length of of weld is the result of multiplying 192 cm times Pi? Or is that scientific notation on your part? Because 192 centimeters (Which is more than likely rounded up, or down to the nearest tenth of a centimeter), already is the circumference of the pipe based on the "nominal" size OD (24inch OD pipe X 2.54 = 60.96 cm X 3.14 = 191.4144 cm), but we all know that the circumference is going to be slightly larger than 191.4144 because after all, 24" OD is a nominal size, and the actual OD is slightly larger than the nominal size listed and Pi is usually as many more decimal places to the right as one wants to use for the sake of accuracy! ;) So, if you meant that the total weld length is 192 centimeters, then please disregard my question. ;)
In other words, multiply the rounded off circumference, or not (for accuracy's sake! ;) ) to the weld width, then multiply that sum by .02 as GRoberts mentioned which will then give one the maximum porosity area permitted....
So the only value that's missing here is the weld width which is to be multiplied by 192 cm (Or a more accurate value instead ;) ), and the sum of that to be multiplied by .02 which will then give you the maximum porosity area permitted. ;) However, if one wants to be really accurate, then one must use actual values as opposed to
"nominal or rounded off or up" values in their calculations because they may very well make the difference between what is truly acceptable and what is unacceptable IMHO. ;) Especially if there are no tolerances to work with when one performs the calculations. ;)
