I suggest your 1/16” misalignment tolerance is unduly restrictive. My company’s specs (WPS’s & engineering specs) have permitted an internal, maximum misalignment of 1/8” or 25% of the wall thickness for many, many years without compromising integrity for weldability. It is also included in the specs that internal tapering may be authorized but it shall comply with the governing code, standard, or regulation.
If some of your welders blow an x-ray because they missed an edge, they need to do a better job of fitting-up or learn the technique required to tie-in a 1/8” mismatch.
I would agree with Seldom. Imposing a 1/16” restriction on internal misalignment is excessive. If you have incorporated this into your specification it must be costing you an “arm and a leg” as far as time and money.
I assume that your welders are involved with the fit-up or, at a minimum, check the fit-up prior to welding. If so they are aware of what they are faced with. If they are faced with a misalignment (1/8’ or less) they know they will need to make some adjustments to their technique, and welding variables (within WPS limits) to ensure they have full penetration and they tie-in the edges.
My company also has a 1/8” maximum misalignment tolerance that has worked well over the years.
Good Luck
MM
The hi-lo you are talking about is not bad ,, I assume you are a welder ,, if you think it is to bad to pass x-ray ask your fitter to transition the smaller pipe to match the bigger , and if they are only shooting , 10% of the welds ,, hell ,, just cut the shoulders , when ya run the bead ,, it a be good ,, !!!!!!!!!!
