![](/mwf/attachments//avatars/95-7168.png)
Its real simple, If you need a controlled ramp (rise & fall rate); soak time and chart for records; your best bet is is to use CHP's (ceramic heating pads). If you do not need any of for mentioned, a torch is the way to go.
For gradient: You make the set up to control gradient as prescribed say 100'F per foot in all directions is what we normally shoot for.
Truth be known, if you do not have a record, you did not do a Preheat or PWHT.
Heat is heat (BTU's) if it comes from a CHP or a Rose bud and "structure change" will be in how you apply it.
Time &Temperature are horse's of a different color though and must be controllled and recorded.
Just for posterity you said "TORCH" not an oven with a flame.
