Up Topic Welding Industry / Technical Discussions / Classifying Weldability?
- - By Brian F. (*) Date 06-27-2002 14:42
How is the weldability of steel classified? I know carbon content is one of the major factors, but what effect does the content of phosphorous and sulfur have on weldability?
Thanks,
Brian
Parent - - By pipewelder_1999 (****) Date 06-27-2002 16:23
This is from "Weldability Of Steels" by RD Stout.
Sulfur
" ... The welding of steels containing sulfur contents of .10% or more for free machining characteristics is often troublesome, ..... Sulfides present as elongated stringers increase the susceptibility of base plates to lamellar tearing. (There is much more than this with refernce to the combination of sulfur with O2 and H2 and it seems to indicate that some steels with excessively low amounts of S can be more susceptable to deleayed cracking)"
Phosphorus
"... As little as .05% results in noticable increase in yield strength and a corresponding decrease in ductility. Phosphorus tends to segregate readily. It difuuses too slowly to permit homoginization in normal heat treating or welding processes, and thus may cause harmful banding, and diffusion of carbon away from high phosphorus areas. Nevertheless, good welding results have been obtained wih corrosion resistant low alloy steels containing approximately .15% phosphorus for improvement of corrosion resistance."
There should be someone that could simplify or add to this information I quoted. I thought this might get you started. If my knowledge were greater I could possibly add more but thats not the case.
Gerald
weldinginspectionsvcs.com
Parent - By Brian F. (*) Date 06-27-2002 16:52
Thanks!
Parent - - By GRoberts (***) Date 06-27-2002 17:24
One way the weldability of steel is classified is through susceptablitiy to delayed cracking (cold cracking/hydrogen embrittlement/etc...) the general formula that is used that determines a steels comparitive susceptability is this: Pcm = C + (Si/30) + [(Mn + Cu + Cr)/20] + (Ni/60) + (Mo/15) + (V/10) + (5B)
Another factor in weldability is hardenability. One way to determine the hardenability of steel, called the Carbon equivalent. As you mentioned carbon is a major factor in the weldability of steel. This formula basically, determines how much carbon would be in the steel if all the elements that act to increase hardenability were converted to carbon. The formula for CE = C + (Mn/6) + [(Cr+Mo+V)/5] + [(Ni+cu)/15]
The phosphorous and sulfer have several effects on weldablility. One is that they contribute to hot cracking of the weld metal. They also detract from the toughness of the weld/HAZ/base metal. I have never run into problems with too low of a sulfer as quoted above from RD Stout. We routinley weld on base metal that has less than .001 % S, and it usually helps our CVN tests quite a bit as compared to higher S containing base metal.
Parent - - By Cain (*) Date 06-27-2002 18:06
1) What is the Pcm range for steels: low, med, & high?
2) What is the CE range for steels: low, med, & high?
Parent - - By GRoberts (***) Date 06-27-2002 20:08
I don't know if there is an industry standard for low/med/high CE and Pcm. Usually you are most worried about CE and Pcm when you are trying to determine preheat/pwht/heat input type of variables. For steels without preheat/pwht, a common limitation is .5 CE max, and .25 Pcm max.
Parent - By Cain (*) Date 07-05-2002 12:44
Thanks!
Parent - - By Jorge Giraldo (**) Date 07-03-2002 20:20
Hi Cain:
Just as GRoberts says, I don't know any classification about the CE and Pcm values, but there are some info that can serve you. Matsubuchi propose that a CE greater than 0.4 indicates that your steel is susceptible to delayed cracking then you may need preheat depending of your thickness.
If you have the AWS D1.1 or AWS D1.5, they includes an appendix related with Guidelines on Alternative Methods for determining preheat where you can get different preheat temp. levels according the CE or the Pcm.
Jorge Giraldo
MedellĂ­n, Colombia
Parent - By Cain (*) Date 07-05-2002 12:45
Thanks!
