this was the response from the supplier
The pictures are exactly what we needed to determine what the situation was on this pipe. Please note that based on the picture, this is IP (incomplete penetration) where the OD/ID welds didn’t quite meet all the way. THIS IS NOT A CRACK. The only way to catch something like this is with xray, ultrasonic testing or other NDE means that are NOT required by standard ASTM/ASME SA790. ASME has a joint factor of anywhere from I believe .70 to .85 for a double welded product like this, unless xray is required. 100% xray would take a welded product to 1.0 joint factor. Dye penetrant testing is also not a requirement of ASTM/ASME SA-790.
Basically, while we wish every piece of pipe we produce would pass xray, there is no way to guarantee that unless xray is ordered. This pipe was produced and tested in accordance with ASTM/ASME SA-790.
we had to buy new pipe.............
they sent another pipe ..... now this pipe is marked sa-312 and sa-790
how does that work?
Im not happy about this pipe the supplier sent a reply from the manufacturer.
He says The pipe is not x-ray quality and has been tested to sa-790 .
So for a pipe with a MIN wall thickness of .322 1/8 of that can be unfused and its acceptable?
i could not sleep at nite with that pipe on a vessel of any kind.
this indication Bled like a Stuck Pig.
we took an xray and its along the whole length, DARK AS DARK CAN BE.
WOULD ANY OF YOU ALL USE IT?
