Up Topic American Welding Society Services / Certifications / API 1104 "rod"
- - By plrwelder (*) Date 03-09-2010 21:10
As I've said in the past I am new to rig welding and have taken a couple different tests... but my question now is what rod is normally used on a branch test 5p,70++ ....etc the tests I have taken have been 5p root and hot pass and 7010 or 70+ fill and cap is this normal? Cause I have also heard of 7010 or 70+ all the way to?
Parent - By G.S.Crisi (****) Date 03-09-2010 21:26
Back in my days of erector engineer (and I'm talking of the early seventies) I've used E 7010 for the first pass and E 7018 for the subsequents.
5P is a Lincoln brand of electrodes. We used another brand (Philips, if I remeber well)
Parent - By dbigkahunna (****) Date 03-10-2010 00:32
Depending on the pipe and what you are testing for you may run the bead with 5p+, 70+, or HYP. Hot pass can be 5P+, 70+ or HYP. There is no "common" rod used. A lot of companies use 5P+ and 70+ for just about everything while others don't. You just have to ask the welding boss where you are testing what is to be used for that company on that day.
