our shop uses all walter 4 1/2" , we are fabricating with stainless and using zip cuts and buffing discs mostly, we have had good luck with these. we use the one with the switch on top which makes one hand operation easy.
Hi,
We have tried nearly everything out there! We do mostly pipeline and general repair and maintenance, so our equipment is exposed to dirt and mud and often rigorous work. For my money, I've found that Milwaukee's small grinders give us the best value for the dollars spent. Have had only one go bad, and that was because of gravel getting into the armature space!
We prefer the paddle type switch. The thumb switches wear in the locking mechanism and then you have to hold the switch continually for operation which can be awkward and tiring. The amount you pay for a grinder doesn't always translate into
longevity! We buy the less powerful Milwaukee (6amps) as it gives good power with a comfortable size. Also, the factory reconditioned units are sometimes available at real savings in price, and come with full warranty. One of my sons buys the
Harbor Freight grinders for 20.00. His have lasted as long as any of mine! I've never had much luck with the yellow, black, grey,green or blue grinders, regardless of price. Hope this helps.
