I would say it probably won't make a bit of difference but it isn't up to me of course. You need to NCR the joint and propose a disposition as is.
Not to mention most likely requal a weld procedure.
However, it would probably be cheaper to just cut it out as opposed to requaling.
yah JS has the answer, you could requal the procedure with 80s-2 and do bend tests and tensile pulls and see if the material will work in service. If it's just one joint or a few joints, probably faster and cheaper to cut out and reweld.
