Up Topic Welding Industry / Metallurgy / No. of passes
- - By mohamed radwan (*) Date 03-21-2010 12:19
is it true that the number of passes is 3 or 4 (the first bead then the second and/or third then the cap weld ) ?
in which cases should i use 3 passes or 4 passes ?
thank you all
Parent - By alkhiat (*) Date 03-21-2010 14:37
number of passes has a Direct proportion with metal thickness it amy be one ,four or more related to metal thicness
- - By mohamed radwan (*) Date 03-22-2010 23:06
thank you
is there any relation or table i can find this relation between them or it comes by experience
Parent - By G.S.Crisi (****) Date 03-23-2010 00:12
It comes from experience, Mohammed.
- By mohamed radwan (*) Date 03-24-2010 17:10
thank u Geovani
