Up Topic Welding Industry / General Welding Discussion / Backing Rings
- - By Blaster (***) Date 03-23-2010 22:21
Who is a good supplier of backing rings (with spacing pins)?
I need a couple hundred a year for 8" schedule 80 pipe.
Parent - By aevald (*****) Date 03-23-2010 22:48
Hello Blaster, check out Ferguson Pipe and Supply, at least I think that's the name they go by, that's where I got mine from. Best regards, Allan
Parent - - By MBSims (****) Date 03-23-2010 23:41
We use Robvon or Imperial Weld Ring.
Parent - - By joe pirie (***) Date 03-24-2010 03:26
call James  at windustrial 562-529-2520
Parent - By Blaster (***) Date 04-15-2010 19:35
A belated thanks for the replies - I have been real busy for the last couple of weeks and haven't been on the forum.
After checking with Imperial and Robvon, who appear to be the only two US manufacturers, I decided to get a Roper Whitney 383 HD set of slip rolls (all rolls driven) to roll my own.
I was looking at about $2.85 - $3.15 per ring, and the shipping across the country for a barrel of 200 was a killer.  It came out to about $4.50 per ring total by the time they would get here.
Thanks again for the info.
