Up Topic American Welding Society Services / Certifications / ASTM A513 GRADES? TENSILE ?
- - By david bean (**) Date 04-02-2010 16:16
I have Conducted a PQR using ASTM A513 round tube using .035 NR- 211.  The tension specimins failed in the base material away from the weld 56,000 lbs.
Is there a specific tesile strength for A513?
I would assume that this PQR would pass because it broke away from the weld,  but i need some clarification on this matter.
Parent - By Mikeqc1 (****) Date 04-02-2010 22:25
Im sure there is, but i dont have any specs at home.
look at the base materials MTR what were the tension test results?
sometimes they put the max and mins in the tale @ the top.
did it fail outside the HAZ?
I would look at the Specs for the base metal.
Id say ASTM513 as a spec.
google the material to get an idea if its in the range.
MDK
Parent - - By waccobird (****) Date 04-03-2010 00:15
david bean
check page 2 of the pdf
http://www.amcastle.com/pdfs/carbonandalloytubing.pdf
It depends on the type of the A513 you have it could range from 45,000 to 80,000.
Good Luck
Marshall
Parent - By Bob Garner (***) Date 04-05-2010 15:13
I have the 2005 Edition of A 513 open in front of me.  As noted, the strength depends on the Grade Designation.  Strength also depends on how the tubing is made - as welded, normalized, drawn, etc.
