Yes! BTW,
"WELDCOME TO THE WORLD'S GREATEST WELDING FORUM saitsa!!! :) :) :)"For instance, one needs to qualify to the smallest size diameter being used in production in order to qualify all other diameters, or if the production diameter is the only size being welded at a minimum if one is also working to B31.1. Now, I don't remember if this also applies in any of the other B31 standards, so I'll just stick with what I remember when I qualified 1/2 schedule 10 316L stainless steel with GTAW both manually as well as with a machine in a fixed position, but the machine qualified the welding operator only for machine welding and manually covered both... Then again, it was six years ago, and things might have changed since. ;)
