Hi Daniel Castleman!
ROTFLMFAOAAA!!! Keep coming back kid!!! You'll learn a lot in here no matter how much you think you know at such a young age!!! :) :)
1984???? Man!!! I was already welding for a living over ten years by the time you were born, and I was very much still "Wet behind the ears" back in those days!!! :) :) :)
Now Daniel, you need to give us much more information beside what you gave us in your original post because without it we cannot give you an educated as well as an experienced piece of advice. So please do so! ;)
What should you include??? First, the grade of steel, the grade & diameter of filler wire, the type of shielding gas being used & flow rate, CTWD, whether or not the contact tip is recessed or not in relation to the nozzle... You mentioned that it was for unlimited certification using 1" plate, but you didn't mention which code specifically, or whether or not a backing strip was used, or the root gap & land if any... Whether or not there was any pre-heat & interpass temperature controls, etc.
So if you could provide us with as much information as possible ,we could give you combined, some pretty sound suggestions which could help you in passing the test in the future at the very least, because after all as Steve mentioned in an earlier post, We're NOT mind readers!!! ;) ;) ;)
Btw, I have given that test to many, many (in the hundreds) students in the past also and from my experience, it's not even close in comparing how many students failed because of improper technique which was the use of a forehand technique as well as excessive travel angle also!!! ;) When compared to the use of the backhand technique along with the proper travel and work angle, CTWD, shielding gas for spray transfer of mild steel, etc., the failure rate with the use of the forehand technique was overwhelmingly more frequent due to LOF and incomplete penetration between the passes.
So there are a lot of variables that can contribute to either passing or failing this test, and technique is an important one yet not the only one IMHO!!! :) :) :)
Please tell us more details and btw I almost forgot!!!
"WELDCOME TO THE WORLD'S GREATEST WELDING FORUM!!! :) :) :)"Respectfully,
