Up Topic American Welding Society Services / Certifications / PQR's per AWS B2.1
- - By aerowelder (*) Date 04-19-2010 21:22
I',m trying to qualifiy a weld procedure per AWS B2.1 using 718PH Inconel seamless tubing, welded to 718PH sheet, .032" thick. I cannot find the following; The M number, group number, the specification,type and grade for either the sheet or tubing. Any help would be greatly appreciated. Thank you`
Parent - By Lawrence (*****) Date 04-19-2010 22:23
A little research here may get you what you need.
http://www.specialmetalswelding.com/
If not,,, contact them directly... They will be happy to get you on your way.
