Up Topic Welding Industry / Technical Discussions / Oxy-acetylene welding: how shield?
- - By DaveSisk (**) Date 07-22-2002 19:59
With oxy-acetylene welding, what shields the weld pool from the atmosphere? Is it the gas produced by the oxygen and acetylene burning? Or do you use filler rods that are flux-coated? (You can fuse parts without using filler metal with oxy-acetylene right? I'm thinking the gas produced from burning the other two shields the weld, but I'm just guessing...)
Dave
Parent - By CHGuilford (****) Date 07-22-2002 20:08
You are correct in that the combustion gases from the torch is the shielding. That is one reason why you don't want an oxidizing flame because there is too much free oxygen that will react with the metal.
CHGuilford
Parent - By G.S.Crisi (****) Date 07-23-2002 15:31
When welding copper and copper alloys you must dip the rod tip into powdered borax. The borax melts immediately at the contact with the flame and this is what isolates the metal from atmosphere.
But this is valid only for copper and its alloys.
Parent - By stich585 (*) Date 07-24-2002 03:46
It depends on what the base metal is made out of. For instance, You need to coat your filler rod with flux when you weld brass. One of the main contaminents in the air is carbon. If you are welding a carbon steel, you don't need as much protection from carbon as when you are welding copper or brass.
