First off drpmcwi,
"WELDCOME TO THE WORLD's GREATEST WELDING FORUM!!! :) :) :)"Now, as far as you being able to inspect work to AWS D1.5 is concerned, as long as the contract docs and the customer accepts you as a CWI wh tested to D1.1, then there is nothing written that prevents you from performing VT and any other AWS CWI work on a D1.5 job... However, if the EOR, contract docs, and the customer requires someone who initially tested to any code in order to achieve CWI status other than D1.5 also has to have an additional AWS D1.5 endorsement in order to perform the expected duties on a particular job, then you will be required to have earned the AWS D1.5 additional endorsement qualification besides what you already have earned as a Certified Welding Inspector.
So it all depends on the specific job requirements set forth by the client and if there are none at all for a particular job, then you don't even have to be a CWI either!!! ;) Clear as mud eh??? :) :) :)
