Up Topic Welding Industry / General Welding Discussion / Back up rings for type M pipeing asme B31.3
- By joe pirie (***) Date 05-04-2010 22:33
Contractor wants to use back up rings on ASME B31.3  Type M pipeing
the way Im reading the code it says you can use continous backing but
not the split ring backing.Is it acceptable to pre weld the backup ring
prior to tacking in pipe joint ? Thanks  Joe
