I am going to print out a template at HarderWoods.com. I have used these before with alot of good results but never had to offset. My question is do you measure along the circumfrence from the centerline of the pipe to the center of the branch, or do you measure level from the centerline of the pipe to the center of branch. I am in no way a pipe fitter so any help would be appreciated.
