Up Topic Welding Industry / Technical Discussions / Oklahoma welding
- - By Jim Hughes (***) Date 05-07-2010 21:08
For all the pipeline welders welding in Oklahoma. Does Oklahoma require you to get some kind of welding permit or license when you test? Or when you pass your welding test do you have get some permit from the state of Oklahoma to weld?
Jim
Parent - - By 522029 (***) Date 05-07-2010 23:52
You must pass a  "state test" before you are allowed to take a jobsite test.  It is not a permit or license but a certification.
Griff
Parent - - By Jim Hughes (***) Date 05-09-2010 20:59
Thanks.
so you take a test from a state reconized facility and submit paper work to the state?
Parent - By 522029 (***) Date 05-10-2010 00:45
Yes.  There are several facilities around the state, usually Vo-Tech schools where the testing is performed.
You can go to the Oklahoma Dept. of Labor website and find the list of testing sites.
http://www.ok.gov/odol/Licensing/index.html
Griff
