"'Normal' is essentially perpendicular to the weld surface. "-quote
Jeff, shouldn't that read.... " parallel to the weld surface"...?<----forget I said this, read below.
EDIT:
OK....I think the term is a bit mis-leading...after looking at the definitions again, I agree with Jeff....C-Table 6.1 Item 8(page 483 in 2008) describes the situation and also references Annex K.
After looking at Annex K,..... Piping porosity is different than elongated piping porosity.
Piping porosity is PERPENDICULAR to the weld surface,
.....while Elongated piping porosity is PARALLEL to the weld surface.
Clear as mud?
