I am fairly new to the "formal" inspection part of this. When plate is "rolled" into the shape of pipe/tube, even though for structural, would the welder not need to be qualified to weld pipe/tubing?
Sounds like a long seam joint. I've qualified for that type of joint with a 1G plate test, FCAW and SAW.
The short answer is "no". Qualification on plate should suffice.
Is this a girth weld or longitudinal seam weld?
By weldteacher
Date 06-05-2010 00:19
Edited 06-05-2010 00:22
Thanks for your response. Bob, this is both. After welding the formed tubing longitudinally, it is then welded to plates at each end with fillets. Also, this is D1.2.
