Up Topic Welding Industry / General Welding Discussion / FERRALIUM 255 Alloy
- - By jim parker (**) Date 06-15-2010 16:28
Anyone familiar with this material?  Ferralium 255 alloy, Im trying to locate a FCAW Filler wire any recommendations?
Parent - - By js55 (*****) Date 06-15-2010 20:41
Jim,
By the question I suspect that you have greater need than the filler, which is not uncommon. There are several manufactuers that deal in the duplex fillers for a 25-5.
The first thing however I would suggest is do a forum search on duplex and research what has been well said in the forum already.
You should find quite a bit.
Though Ferralium is readily weldable, the welding 'window' for Ferralium is narrower than it is for the 2205's. And corrosion testing if imposed can be a problem, depending.
Parent - - By Tommyjoking (****) Date 06-16-2010 04:18
I just want to bump this for everyone's education...I have never seen it myself.
Parent - - By jim parker (**) Date 06-16-2010 12:04
Tommy you from Searcy?  Anything going on in that area?
Parent - By Tommyjoking (****) Date 06-16-2010 21:28
Yea  Jim  I am from the area, use to live in Searcy.  I am about ten miles up the goat track that passes for a highway here.  Cal Frac, Cheasepeke and gobs of pipeliners are all over the place.  I have no clue about any work avaliable tho...I see trucks with 798 plates at the unemployment office regularly.  Far as anything else, I have been out of work for 6 months....
Parent - By jim parker (**) Date 06-16-2010 12:42 Edited 06-16-2010 12:46
Js55,
Thanks for the info Ill try a search on this forum. Im trying to learn all i can . I found Cor-Met ot of Brighton MI. a good source for duplex fillers, Thay have been very helpfull.
