"See D1.1/2010 2.18 Prohibited Joints and Welds. 2.18.2 states that bevel-groove and J-groove are unacceptable in flat position if V or U joints are practicable."---quote from another thread
See 2.17.2 in D1.1:2008 for the same reference.
What does it matter, if the joint is to be back gouged from the other side.......if you have a lack of penetration to the bottom of the groove, you will be gouging it out and rewelding anyway.
