Up Topic Welders and Inspectors / Education & Training / eye test
- - By david rutter Date 07-13-2010 18:19
does anyone know of a standard eye test that can be given to enrolled welders to determine their capability of welding without correction?
Parent - By jrw159 (*****) Date 07-13-2010 18:26
Jaeger 1 or 2 eye tests are pretty standard for the industry.
http://www.amazon.com/Jaeger-Reading-Test-Type-Plastic-Chart/dp/B000FLYTBA
jrw159
Parent - By jwright650 (*****) Date 07-13-2010 18:32
My suggestion is the same as jrw159's
Parent - By Lawrence (*****) Date 07-13-2010 19:38 Edited 07-13-2010 19:42
The only AWS code that deals with "Welder" vision requirements is D17.1 Aerospace Fusion Welding spec.
"4.2.1 Physical Requirements.  Welders and welding
operators shall have vision acuity of 20/30 or better in
either eye, and shall be able to read the Jeager No. 2 Eye
Chart at 16 in.  Natural or corrected vision may be used to
achieve eye test requirements..."
Edit:
David...  I keep a selection of Cheaters (mangifying lenses) in the lab..  from 1.5 to 2.5...  When I see students struggeling and it's obvious they can't see what they are doing..  I will let them try out the cheaters...  It can be a real epiphany to suddenly be able to see the puddle clearly...   They are only a couple of bucks each.
Even experienced welders often don't think about vision getting worse over the years.  They just think.. "I used to be able to do this and now I can't"
