I can't say if you're 100% correct, but I have worked in a defense manufacture's facility that either currently did, or in the past, use SS to weld non structural joints for joining high hard to other steel alloys. You will need to look at controlling preheat though because the SS does nothing for the HAZ of the base metal, which may or may not get detrimentally hard.
