What diameter wire would any of you reccommend for welding a material thickness of 1.2mm? The material being welded is 300 series SS and we are currently using a 307L solid wire. Everything I have found states that a .030" - .035" wire is what is reccommended. I was just wanting opinions of others as well. Thanks.
