I have experience welding 6061 AL to 304. It is a tough task to say the least. Like mixing oil and water.
There are really only two welding processes that might work: friction welding, and explosion bonding. With both of them, you really end up with what resembles a diffusion bond with no visible fusion zone on a metallography view. The welds are also brittle.
We had to withstand thermal stress of about 400-500F. The thermal expansion stress differences were enough that we had massive problems with cracking the brittle welds in service. (We needed a hermetic seal for a jet engine part).
Our yields were as low as 25% with friction welding. We switched to explosion bonding and got yields up to 85%.
We did not try brazing. Some people have tried brazing al to ss. There are problems with brittle intermetalliac compounds with brazing even. Also, they say plating is reqired. I think they use a tantalum or titanium interlayer.
Good luck!
