Up Topic American Welding Society Services / Certifications / High pressure certifications
- - By snoopbuzz Date 07-21-2010 00:44
Does the AWS offer any certifications for fossil fuel piping above 90 psi or do I have to look into an ASME certification?
I have searched numerous websites for information, even Lincoln electric and Hobart but have not found anything
that is specifically for pressures above 90 psi. I might just not be looking in the right place but would appreciate any
information that was provided.
Parent - By jarcher (**) Date 07-22-2010 17:00
Check the scope section in Chapter I of D1.1.  Pressure piping is specifically excluded from D1.1 regulation.
Parent - - By basecamp2 (*) Date 09-04-2010 20:31
yOU CAN TRY GETTING IT THROUGH THE ASNT/ACCP PROGRAM, i'V BEEN AN iNSPECTOR ON ALL DIFFERENT TYPES PRESSURE PIPES,BOILERS,CODED DRUMS AND VESSLES, EVEN REFINERY REACTORS, AND I AM GOING THROUGH HELL GETTING THIS DONE
Google ASNT/ACCP level ll
Good luck
Parent - By 803056 (*****) Date 09-06-2010 15:23
Are you interested in welder performance qualification or inspector qualifications?
