The material is known as a High Strength Low Alloy steel (HSLA) from the Quenched & Tempered (Q&T) type. In general this steel can be welded using any welding proces. But GTAW and GMAW are preferred because they are resulting in better impact toughness. Use of SFA 5.1 or 5.5 welding filler is common.
This type of steel can suffer from cold cracking, wich can be prevented by prehaet. But, the typical structure of A514 gained from basic heat treatment during production of the base plate material can be destroyed after excessive preheat ! High preheat results in both decrease of toughness and strength. Typical preheat for thickness 2" is 175-325 °F (105-190°C).
Another aspect is the heat input during welding and the interpas temperature : can have the same negative effect on the structure as preheat ! Welding must be done in multi-layer technique : thin layers with low heat input.
PWHT is not recommended : again negative influence on the properties.
